Possible to fix broken radiocable mount?
Hi
When trying to fix my phone I sadly broke my radiocable mount. (only the upper) This causes bad signal on my phone. Is there a solution to this problem? Could I simply just glue it on?
Help needed!
edit: The problem is that the blue cable should have a munt within the red circle as shown on the picture. On my phone the little ring around the little "nipple" in the middel is gone /or stuck on the cable. This causes bad or no conection whtch causes bad signal.
Apears to be better when i hold the cable in the right place with my fingers.
Update (08/21/2016)
I was not able to take a good picture. However i tried to draw (whit poor skills) the problem. It is the circkle that is missing. The squere is black and beneth the circkle and middel dot, i dont know if it has any function at all. It seems to work as intenden when held in place. Witch I think suggest that it is just the munt that is broken not the conection. The thing in the middle that goes in to the hole in the cable is still there.
Hopefully the drawings will be suficient:) Thanks a lot for the help so far!!! Verry gratefull
Es esta una buena pregunta?
2 comentarios
@marste post an image of what you broke and where it's broken with your question. that way we can see what you see. Use this guide for that Agregar imágenes a una pregunta existente
- de oldturkey03
@oldturkey03 now i have a picture. Thanks for the help so far:)
- de Martin Steimler
