Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Unresponsive screen when installed
My screen works fine when not Clipped in and screwed in, but when I push it down and clip it in it becomes unresponsive. If you keep the phone open and pull it it a tiny but it works, but pushing it in and clipping it in renders it useless. I've resat the connectors 20+ times but I don't know.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Solución Elegida
If the front display ribbon cables feel like they clip in 100% fine and you have tried cleaning both connection points with 99% isopropyl alcohol and have tried holding the power button with the battery unplugged for 10 seconds.
Then I think it's safe to say you got a faulty screen. I had a iPhone 5S screen that did this exact same thing. Is the housing of the iPhone 6 as dented in or bent in any way that makes the screen not sit flush?
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
Not to a serious degree. I mean it has drop marks and small dents but no big deal. Nothing to be in the way of the screen
- de
what does holding the power button with the battery unplugged do?? I'm curious i've never heard that method.
- de
Drains any residual power in the circuit (or any connected internal components) of the phone. It has fixed an issue once where the touch screen was behaving erratically on a new screen.
- de
Respuesta Más Útil
You have a problem with the flex cables on the screen.
Puntuación 3
1 comentario:
It's a brand new screen
- de
As someone else has said, you have a problem with the flex cables, they are torn inside, therefore you need to install a new screen on the device in order to fix this issue.
Puntuación 2
Añadir tu respuesta
monsterjamfan30 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 236
