Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Anunciado - 2014, noviembre El Samsung Galaxy Core Prime (G360, G361) funciona con un procesador de cuatro núcleos a 1.3GHz y viene con 1GB de RAM. El teléfono incluye 8 GB de almacenamiento interno que se puede ampliar hasta 64 GB mediante una tarjeta microSD.
fix crack at home
how can i fix cracks manually, at home, without buying or paying for anything?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
You will at least have to buy a glass for the screen and replace that, but a glass is like $8 with free shipping. Be warned though, glass only is very difficult, and you will more likely than not ruin the LCD.
glass
http://www.ebay.com/itm/like/30199621611...
some resources to look at on glass repairs(you should look up more, this is just a starting point)
http://www.youtube.com/watch?v=z9drzO9hO...
https://www.youtube.com/watch?v=SJ05sPZD...
Fue útil esta respuesta?
Puntuación 2
I have to concur with Ethan on this one on having to at least by replacement glass. Although I have done a few of these core Primes with no damage to the lce as they are not laminated together.
Puntuación 2
2 comentarios:
Would just changing a cracked glass on a core prime be easy? it's not badly cracked and the frame under it has no damage at all. its a core prime g360t1.
- de
Yes it only has adhesive on the edges of the device you have to worry about around the home button and in the upper right hand corner so that it doesn't cut cables.
- de
Añadir tu respuesta
tlomov estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 17
Todo El Tiempo: 1,328
