Why is my coffee not hot enough?
Whenever I try to use the Keurig, the coffee doesn't come out hot enough. Please help:(
Es esta una buena pregunta?
You may have a problem with your water pump. See troubleshooting page.
Fue útil esta respuesta?
The temperature can also be set on the display via the menu but it is generally a sign that something else isn't working.
Why isn't my coffee hot
If you change it in menu to 192° and it still comes out cold, go to ebay. For 20 bucks you can get a new tank/boiler, usually ships free. Not a fun repair but doable easily once the case is off
There might be three possible reasons if your Keurig is not hot enough
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 108
Todo El Tiempo: 12,312
1 comentario
It's not hot when I finish brewing
- de Adele Martin
