Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Canon PowerShot SD1300 IS es una cámara digital compacta lanzada por Canon en 2010.
it was dropped into water now getting lens error message
I have a Canon Powershot SD 1300 IS . Luv this camera.
My friend accidentally flipped it off a table into a bowl of water. I got it out quickly & dried it out. Now I've turned it on the lens extended on its own & I can't get it to retract. And now when I turn it on I get a "lens error message"Help please.
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
I have the same camera and the lens is stuck and won't move. when I try to move it, the camera shuts off. I would appreciate some help with this.
- de
Agregar un comentario
1 Respuesta
Just a few years late and only answered for completion sake. Who knows? Somebody may just run into issues with their "old" camera. Anyhow....
You will need to have to treat this just like any other water damaged device. For now, you want to stop continuing to try to operate your camera. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your camera using these guides as well as something like this video. Remove the main board. You must remove the EMI shields from the circuit board. After you remove those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide Even so it was written for an Apple iPhone 3G, all the points are still pertinent to your camera as well. While you clean your board etc., check for any obvious damage, like burned or missing components etc. When it is properly cleaned, you must be ready to replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your camera and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad lens since it is uncommon for a lens to fail due to water damage. It may have gotten knocked of track when it got submersed. Take a look on here for some ideas on how to get it back to working condition. If none of those work, use this guide Canon PowerShot SD1300 IS Lens Replacement to repalce the lens. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Imagen de iPhone
Guía
Reparación de los daños en un iPhone debido a la entrada de líquidos
Dificultad:
Difícil
1 - 2 hours
Imagen de Canon PowerShot SD1300 IS Lens
Guía
Dificultad:
Moderado
10 - 25 minutes
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Boxxies estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 324
