Saltar al contenido principal
Canon PowerShot SD1300 IS Lens Replacement
Qué necesitas
  1. Canon PowerShot SD1300 IS Lens Replacement, Lens: paso 1, imagen 1 de 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: paso 1, imagen 2 de 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: paso 1, imagen 3 de 3
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
    • Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
  2. Canon PowerShot SD1300 IS Lens Replacement: paso 2, imagen 1 de 1
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Lens Replacement: paso 3, imagen 1 de 1
    • Use one of your plastic opening tools to separate the screen from the main body of your PowerShot.
  4. Canon PowerShot SD1300 IS Lens Replacement: paso 4, imagen 1 de 1
    • Remove five of the 3mm J00 screws under the screen to release the lens for replacement.
    • Lens assembly should be removed through the front of the camera once screws are removed.
Conclusión
2 personas más completaron esta guía.
Clayton
Miembro Desde 03/20/17
560 Reputación
5 Guías creadas
Equipo
Un comentario
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
Greg Reinhart - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 36
Todo El Tiempo: 1,545
