Broken Charger Pin DC-in board
Hello,
My charger pin broke off inside my laptop. I have tried tweezers, and have had zero success.
Anything else I can try would be greatly appreciated.
thank you so much,
Kristi
Es esta una buena pregunta?
Hello,
thank you so much,
Kristi
Open it up and remove the DC-IN port. Pull the center brace on the back of the DC-IN port out slightly. This will allow access to the broken pin.
Here's how to get to it:
PowerBook G4 Aluminio 15 "1.67 GHz reemplazo de tarjeta de CC y sonido
Fue útil esta respuesta?
Power off and battery removed. I would screw a small screw into the part stuck in the computer and then remove it carefully with a pair of pliers pulling on the screw head. Good luck.
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,282
