Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un gran teléfono inteligente de LG, lanzado en otoño de 2014. El LG G3 (D855) cuenta con una pantalla IPS Quad HD y una cámara de 13 megapíxeles.
SD Card Slot not working properly
As it says in the title. The SD Card slot in my LG G3 is not functioning properly. It will mount and then unmount the card repeatedly and endlessly. Is there any way to fix this or repair the slot?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Have you tried another microSD card? The microSD card slot may be physically damaged or burnt inside if it still doesn't work.
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
I've tried 4 different sd cards and they all had the same result. I've also tried cleaning it some with isopropyl alcohol and canned air to no effect. No clue as to how it could have been damaged as it just randomly started doing it the one day.
- de
Did you ever get this fixed, OP? I've been having the same issue for months now and I can't ignore it anymore
- de
Unfortunately I was never able to get it fixed. I ended up getting a refurbished G4 for 200$.
- de
Thanks for the answer! I've resigned myself to a new phone (V20) as well...
- de
Añadir tu respuesta
mitchellblu3 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 38
Todo El Tiempo: 3,330
