acer screen gets white after starting
Just as I push power button screen goes white and a small portion in right side of screen has a black color.
Laptop detail
Aspire 5750 series
Model no P5WEO
Os:Window10/ 32 bits
Es esta una buena pregunta?
Laptop detail
Aspire 5750 series
Model no P5WEO
Hi,
It is either the LCD screen or the flex cable that connects it to the motherboard that has the problem. Check the flex cable connections in case they have come loose.
Here is a link to the service manual for your laptop. It details how to remove all the various components, including the screen module from your laptop. Hopefully this will help you to isolate your problem. (ignore the title at the top where it says Acer Aspire 5350 Service manual, scroll down and you will see it is the correct one, obviously a typing error).
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 242
2 comentarios
Hi, Try connecting an external monitor and see what it shows.
- de jayeff
External monitor is working very well...
- de mushke azam
