Why will my gun not load?
When I pull back the loading pull lever, it is not locking into place. It pulls back, but it does not set properly. How can I get the loading mechanism to work, so I can use my gun again?
Es esta una buena pregunta?
The most likely cause of this is a detached spring on the release lever. Inside the gun, there is a spring that retracts the release lever after every shot. If this spring is detached or faulty, it will not return the lever to its original position.
This lever is also what the loading pull lever latches onto when you load the gun. Once the spring is reattached, then the release lever will function properly again, allowing you to load the gun.
For more information on this product, see our troubleshooting page below:
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 106
