Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Phone dies at 20%
I recently got a used iPhone 5s from my aunt. It is running iOS 9.2.1 and everything works fine exept for the fact that the phone will die with 27%, 25%, or 20%. When I plug it back in to charge the phone turns on again with the same battery percentage as it had when it died. Is this a software or calibration issue or do I need to replace the battery?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Solución Elegida
i had same issue with my 2 years old phone, at 30% it will totally shut down, what i did is i replaced the battery, now everything is perfect. i used the ifixit battery replacement kit
Fue útil esta respuesta?
Puntuación 1
I would try putting the phone in DFU mode and updating/restoring it.
Let the phone die and then charge to full
If it happens again the battery needs replacing
Puntuación 0
Usually happens when you don’t charge your phone often or the common one, the battery may be old or not working. You can charge it to full and kill it again over and over til it works.
Puntuación 0
Añadir tu respuesta
Vince Parisi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 5,764
