Keeps restarting after screen replacment
I replaced cracked screen on my T83 TELSTRA DAVE 4G and the screen works, it just keeps restarting itself, loads up with the android man then restarts itself constantly
Es esta una buena pregunta?
"Hi, Wondering if the new screen - is it OEM (original equipment manufacturer) i.e. same maker/same part number/serial number (if any) on back of screen or a 'compatible' part? Either way I think that you have proved it to be the problem If OEM it may be faulty, if 'compatible generic make' it may not be compatible. Go for a return as faulty or not compatible with this model"
by jayeff
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 113
11 comentarios
hi, Have you tried a hard reset?
- de jayeff
Hey there yep power button plus up/down buttons doesnt seem to work
- de wisemonk
Hi, Sorry if i'm being a bit pedantic. Did you press and hold the Vol+ button before you pressed the power button, (then holding them together)? Also did you try removing the battery for 1-2 minutes, reinstalling it and then trying a reset?
- de jayeff
I tried pushing all 3 at once, once i sometimes do that the red light just stays on
- de wisemonk
Hi, What happens if it is 'off' and you just connect the charger?
- de jayeff
Mostrar 6 comentarios más
