Saltar al contenido principal
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
Preguntas 99 Ver todo
keurig elite works only with water not k cups
The keurig works fine if you only use water. As soon as you put a k cup itmakes noise but does not brew . I have cleaned every orfice on the unit, including blowing out hoses inside the unit,.Works great if you only want hot water. HELP STARTING TO SHAKE,,,
Es esta una buena pregunta?
Puntuación 9
15 comentarios
if your keurig will work with just got water but will not work with a k cup inserted, the issue is the exit needle on the bottom. I just racked my brain for 3 days with this issue. i took the entire machine apart and then out it back together with no resolution. Wasn't until I put a paper clip thru the bottom needle that everything went back to normal....thank baby Jesus!
The reason the keurig was shutting off with a k cup inserted is because the water would enter the k cup but couldn't drain thru the bottom so all the grounds and water would back up into the top needle which is why the keurig shut off (safety feature)
If you have this issue and this fixes it, let me know!
- de
Tyler! I had same issue. I tired your advice. Worked like a charm! Ty!
- de
My K Supreme still refuses to work. I too have clean every orifice. This is day four of repeating every step as videos show and as instructed.
I am at my wits end ?
- de
That just fixed my issue. Thank you!
- de
I just had the same problem and this resolved my issue, also. Thanks for posting what should have been obvious to me.
- de
Mostrar 10 comentarios más
Agregar un comentario
5 Respuestas
Solución Elegida
Nancy Standal I know you said you cleaned every nook and cranny but it sure sounds like the puncture needles are clogged. Double check those by using this guide.
Fue útil esta respuesta?
Puntuación 12
8 comentarios:
You are. Genius!!! I was about ready to go online and order a new one. THANK YOU!!!!
- de
I just wanted to say thank you from the bottom of my heart for the pictures. I had done everything (I thought) that Keurig said to do but they did not include pictures and I could not see the water flow opening. Thank you so much!
- de
You're amazing! Literally was about to buy a whole new machine and you saved us. Thanks so much for the help!
- de
I have the same problem. I’ve taken it apart, completely removed the needle. Cleaned the entire piece inside and out . I could see clearly all the way thru the needle . Nothing in it or around it. Put it back together . Still won’t brew coffee, only water.
- de
Also ran 4 oz of water thru the water tube
- de
Mostrar 3 comentarios más
if your keurig will work with just hot water but will not work with a k cup inserted, the issue is the exit needle on the bottom. I just racked my brain for 3 days with this issue. i took the entire machine apart and then put it back together with no resolution. Wasn't until I put a paper clip thru the bottom needle that everything went back to normal....thank baby Jesus!
The reason the keurig was shutting off with a k cup inserted is because the water would enter the k cup but couldn't drain thru the bottom so all the grounds and water would back up into the top needle this causing the keurig to off (safety feature)
Puntuación 10
9 comentarios:
My issue is machine won’t make the 4 puncture on the k-cup lid. Makes the one in the center but machine can’t push into the pid to make the others so I get hot water. It’s like the plastic on the top is too strong. Only seems to be brands of tea K-cups not coffee. The coffee have more paper like covering. The tea is more hard plastic. Anyone else have this problem?
- de
Thanks Tyler, the lower needle was absolutely the problem, and this saved us from buying a whole new machine!
- de
My machine doesn't have a lower needle, only the upper one. Is this needed? It will work if I just want hot water but as soon as I put a K cup in, nothing. I have a K10.
- de
I have same problem .these coffee pots are piece crap .will never buy it again .still wont work when i put pod in
- de
We’ve been putting off buying a new coffee maker because we’ve only had our a year. We’ve just been getting coffee when we get to work. Finally! I cleaned this whole thing through, and never realized the lower needle was clogged. You saved us more wasted time, and saved our coffee maker!
- de
Mostrar 4 comentarios más
There are 2 possible problems. The first is you did not punch a hole in the bottom of the K cup when you inserted the K cup or it is clogged as previously mentioned. Most people just close the lid but if the plastic is too strong the needle may not make a hole. Press the cup down before you close the lid may help. Water can now go in on the K cup top and exit on the bottom hole. If this did not work, the air pump may be leaking. When the water is hot, the air pump fills the heater with air to push the water out. The air pump may be leaking and cannot push water thru the coffee but can push it when no cup is installed. Air pump may fail soon.
Puntuación 1
2 comentarios:
Excellent thanks. Yes, it definitely sounds like the latter. It’s been 7-8 years I think. Thank you.
- de
Thank you so much Tyler. This fixed my brand new machine.
- de
OMG Thank you!! I just spent 3 days troubleshooting this. Finally found this forum and watched the video. Fixed my problem immediately. 😌
Puntuación 0
I finally figured out why mu keurig coffee pot won't take reg coffee and it says it will.After purchasing another new Keurig I figured it out..you have to pop out the lil cup from bott with your thumb then the filter cup works.i tried buying every color cause of the holes but nope I was setting up my new pot and bamb it popped right out so I can put my purple filter basket right in..duh!!
Puntuación 0
Añadir tu respuesta
Nancy Standal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 30
Ultimos 7 días: 240
Ultimos 30 días: 1,237
Todo El Tiempo: 38,131
