Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Presentado en noviembre de 2012, este es un ordenador de sobremesa capaz con un procesador Intel Core i7 3770S de cuatro núcleos, 12 GB de RAM y un disco duro de 3 TB. Cuenta con una pantalla táctil de 23 pulgadas, 1080p y sistema de audio Beats Audio integrado.
Why is my computer not turning on?
My computer is not turning on the a/c adapter makes a noise and light blinks but the monitor will not power on I have purchased a new a/c adapter thinking it would resolve this issue and that did not fix the problem any ideas of what I can do?
Es esta una buena pregunta?
Puntuación 3
1 comentario
Computer ENVY 23 not turning on blank screen ! HELP
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Is there a hdmi port or a dvi or vga that you can hook it up to an external monitor to see if it will work that way ? this will tell if the screen itself is the problem . You may also want to try removing one stick of ram at a time to see if the issue is with the ram.
Reemplazo de HP Envy 23-d060qd TouchSmart RAM
You could also try doing a static discharge. Unplug the computer and then hold the power button down for 60 seconds then plug it in and try to boot
. Hope some of this is helpful
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Yes, the static discharge option works with this type of machines.
- de
Añadir tu respuesta
Anayeli estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 7,339
