Why wont the key come out of the key switch?
it seems the key wont turn all the way back, but its not on ascessory. It is in park, but the steering wheel isnt locked. Ive tried to turn the steering wheel while wiggleing the key.
Es esta una buena pregunta?
11 comentarios
The Focus is notorious for problems with the ignition switch. A locksmith would be able to get to it, but that's $$$. Best of luck to you.
- de R Trent
My 05 zx4 is doing the same i would not call a lock smith.. If you disconnect the battery turn the key forward the back it will come out.. I need to know how to fix the problem.. Tem fix i keep one key in the ignition and lock it with the clicker.. If i am parked for awhile i will also disconnect the battery for theft reasons
- de seanwlls
My 2007 Focus zx3 was doing the same thing. Fixed it by pulling this little ring up on the shifter. I guess it isn't hitting the sensor the right way when it falls down.
https://youtu.be/qrJqx3k3nZ0
- de Mark Butler
Thank you Mark Butler. That took me 15 seconds to fix. Why is that a feature on these cars?
- de Lorne Wolfe
THANK YOU !! GENIUS!!! I play with that thing while i am driving.....lol
Knew it as soon as i started reading and burst out in a eureka giggle.
(Answer: 2 responses previous)
- de Larry Walsh
Mostrar 6 comentarios más
