Saltar al contenido principal
El chasis W123 cubre 240D's, 300D's, 300TD's, 280E's y varios otros modelos de coupé, sedanes y vagones Mercedes de los modelos 1977 a 1985.
Preguntas 116 Ver todo
W123 300 coupe rear window
Doing online research about rear window problems ( not rolling all that way down) I've found that is a very common problem, however, answers never seem to be accurate on how to approach the problem, some guiding towards regulators, others to switches etc .
My own problem is that window stop rolling down , when is 3/4 open and 1/4 left to be totally .
Can you please share some data base on your experience at this matter ?
Thanks you very much .
Mauricio Q.
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Solución Elegida
Your best option would be:
Check power to switch
Check power from switch whilst !#^&^$^ button(do this at regulator/ motor)
Now if they both equal around 12V
If you can see the rails make sure they look right
Now with the motor removed You will have to "bench test" motor/ regulator when doing this make sure it rotates though full motion
If it doesn't then that is problem
I can possible suppy a wiring diagram later today or tomorrow
Best of luck
Alex
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thanks Alex, will do. Look forward to ques diag,
- de
hi
sorry about this but i could not find a wiring diagram
- de
Añadir tu respuesta
Mauricio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 994
