How do I wire a tachometer
how do i wire a tachometer on a 1993 jeep grand cherokee
Es esta una buena pregunta?
jimmiller1940, as a general answer since we do not know which tach you have, most aftermarket tachometers only have 3 or 4 wires that need to be connected. Usually a green wire for the tach, red for power, black for ground, and white or yellow for the back light. The power wire that gets connected to a 12 volt ignition source, the tach signal wire that connects to the coil or the designated signal wire in your cars wiring diagram.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 23
Ultimos 30 días: 29
Todo El Tiempo: 973
1 comentario
what make and model is your Tach? Post some images of the connectors with your question. Use this guide Agregar imágenes a una pregunta existente for that
- de oldturkey03
