not charging nor detecting charger.
Doesn't detect charger connection. Battery is full discharged. Random flicker of the screen as if accepting charge. Then nothing including battery is being xharged
Es esta una buena pregunta?
Are you using the original charger? These devices don't like charging from flat otherwise. Another possibility is that the battery has dropped below the 0% mark (3.7v), This is fairly common if it has been left sitting in a flat state
Fue útil esta respuesta?
I've heard around that to fix this is to open up the tablet then unplug and plug the battery connector to fix this problem.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 99
Did you try a different charger?
- de Joel
