Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2690 Ver todo
Saved Imei in iPhone
Where it is saved in the iPHone IMEI?
Es esta una buena pregunta?
Puntuación 1
1 comentario
could you possibly rephrase the question?
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Settings>general>about
Fue útil esta respuesta?
Puntuación 0
5 comentarios:
Sorry. I was thinking in hardware IMEI
- de
Only on the outside of the phone. I don't believe it's printed anywhere on the logic board
- de
Every phone has a unique IMEI: And I ask where is the IMEI is stored in which a chip. If I wanted to change the IMEI what CHIP must be replaced.
- de
I can't advise you to do this. It would contribute to stealing
- de
Dial *#06#
Changing the IMEI is possible but also illegal.
- de
Respuesta Más Útil
You can't, period.
Apple is a group of control freaks, they paired and encrypted almost every chip that has logic functions. So replacing just some of the chips will destroy the device.
For example in order to replace IMEI, the baseband and baseband flash ROM chip must be replaced together as a set, or the device dies. Also the device S/N must be rewritten to pair with the IMEI, or the phone will be denied activation. Rewriting S/N is not yet possible for iPhone 6s, so just forget about replacing chips.
If you replace the logic board, you'll run into another problem. The Touch ID sensor is paired with the CPU, Touch ID dies immediately when you replace just the board, and if you attempt to reinstall iOS, jackpot, the phone dies.
Puntuación 2
Baseband chip is the one with the IMEI.
Puntuación 0
imei saved in iphone on eeprom ic
Puntuación 0
Añadir tu respuesta
Wenzel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 664
