My display only works when plugged into an external monitor
So last week, I tried fixing the loose hinge of my macbook. When I put everything back together, the display does not work anymore. Everything boots up fine except the display does not show anything. So i tried plugging an external monitor and now everything works fine, but my display still doesnt work. So now I have to use my macbook while attached to the external monitor.
Should I buy a new LVDS cable or a new display?
Es esta una buena pregunta?
2 comentarios
Check to make sure to see if you have a backlight. Of course you can always hope it is the cheapest solution which would be the cable , most likely it is an issue with your board.
- de oldturkey03
Could it still be an issue with the board since my macbook turns on and runs fine? The only problem is that I need an external monitor to view the display.
- de Matthew Gatchalian
