Saltar al contenido principal
Guías de reparación y soporte para la linea de portatiles Aspire de Acer para uso domestico y de empresa
Touchpad or cursor not working
Dear sir/Madam,
I bought a acer E5 573 Laptop two weeks ago and installed windows 10 32 bit..
The issue is touchpad is not functioning.. Cursor working with wireless mouse and touchpad works only on windows 7 also but not on windows 10 and 8..
i installed drivers from acer support but still i am facing the same issue..
kindly provide me solution or help me with the issue...
Es esta una buena pregunta?
Puntuación 10
17 comentarios
If i update will my laptop functions properly...?
How do i update BIOS....?
I have video resolution problem... quality of video and games are low... not supporting..
- de
Hi,
I thought you were having Touchpad problems in Win10? Are you now having problems with the video in Win10? Is the touchpad problem fixed?
If you are having problems with Win10, go into Device Manager, make a list of the vendors of your hardware e.g. your Audio is Realtek, BUT Touchpad is either Elantech OR Synaptics, the video is either Intel OR Nvidia, you have to know which one you have so that you can install the latest correct drivers for the device. If something is working OK leave it alone, do not update it until you get everything else working OK. Only update one at a time, get that working properly first, that way you will not confuse the issue.
If you are still in Win7, upgrade and see what problems you have. Again work on one problem at a time.
Updating the BIOS if done incorrectly can HARM your laptop DO NOT DO IT if you don't know what you are doing. If updating the drivers does not solve your problems and you want Win10 go to an expert for help.
- de
I updated windows update... video resolution problem is solved..
but i still have the problem with touchpad...
- de
Hi,
The only thing I can think to try is make a note whether your Touchpad is Elantech Or Synaptics. Download the correct driver from the Acer website. Remember where you downloaded it to on your laptop. Uninstall the Touchpad. Restart the laptop, let Win10 " find the "new" hardware if it asks for driver install the driver that you downloaded. Make sure you have the correct driver!
- de
Thanku... I installed windows 10 64 bit.. now my touchpad is working...
- de
Mostrar 12 comentarios más
Agregar un comentario
8 Respuestas
Solución Elegida
Hi,
The info in this link may help you to solve your problem. I suggest that you do not update the BIOS until you have tried all the other options suggested and found that they have not worked for you.
http://community.acer.com/t5/Windows-10/...
Fue útil esta respuesta?
Puntuación 4
5 comentarios:
Go to f2 after you see the acer logo go to touchpad and un click advanced and click on basic then it will work I just did it on my machine.
- de
Thanks a million! WORKED.
- de
Dear sir
I m facing the same problem with my acer aspire e5-571-31hf . I have applied your above mentioned method but when i going through the boot menu there is no option of touchpad.
- de
On the main option in the bios press Ctrl S. Then set the touchpad to PS2
- de
Newer aspire 3 laptops have the rectangle with a line through it on the f10 key that will turn on the touchpad!
- de
i understand this issue , let me explain how this could effect other components of computer and how this issue can be fixed . just follow these steps and this might help -
restart the computer and removing any program blocking the touch pad d driver to perform commands .
try updating the pointer or touch driver . and restart the computer at last follow this - easy-fix-touch-pad-problems-windows-10 and i hope this will help to solve many this touch issue in computer . thanks
Puntuación 3
1 comentario:
Fantastic! The fix worked - I am over the moon!
- de
You might not update the touchpad driver, right? Go to manufacturer's official website to download the best matched driver and install it with the prompts. Also, you could use Driver Talent detect the most compatible driver. You could install it with just
P.s.: Don't forget to reboot your computer. Good luck. :)
Puntuación 1
I had done a complete reset of the laptop, installed Windows 10 and ran into this problem, I reloaded all the drivers from the Acer site and it didn’t fix it. It was a BIOS issues - restart the computer and hit F2 when the logo appears to access the BIOS menus, go to Main and the Touchpad setting, it seems to default to “Advanced” and when I selected [Basic] and rebooted it is working again!
Puntuación 1
Function + F7. Kid accidentally keyed it in. It took me all day to figure it out.
Puntuación 0
Esse topico ensina resolver esse exato problema https://atshop.com.br/forum/casos-resolv...
Puntuación 0
What worked for me: Go to acer.com, click support, drivers and manuals. Enter your serial number, SNID (see label underneat) or choose model, and then there are a bunch of drivers or BIOS that you can try to download and install. I succeeded on the first try with “Chipset driver”. YMMW.
My symptoms: No touchpad what so ever, but bluetooth mouse and touchscreen working. Keyboard sometimes freezes when doing the Fn-F7 dance (activate/deactivate touchpad). Old Acer v3 111 upgraded to Windows 10.
Puntuación 0
I did a myriad of things but these 3 in this order worked for me.
1. installed the touchpad driver from acer.com in compatibility mode and selected Win 8.
2. rebooted and pressed F2 to get into the bios. Reset bios to default and on the Main Tab selected Basic for the touchpad
3. Pressed F10 to save and exit, and when I got into Windows my mouse was moving.
The only caveat is, I cannot scroll. In my reading I believe that will only work when I switch it to Advanced but when I do, the touchpad stops working again.
Puntuación 0
Añadir tu respuesta
ManiGandan C estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 159,923
