Why want phone come all the way on
my samsung galaxy s2 want come all the way on it goes to where it says virgin mobile then it repeats from the start and want come on any idea what could be wrong with it please help
Es esta una buena pregunta?
Hi,
Try to soft reset the phone :
Turn off the phone, take out the battery, then press and hold the ON button for 10-15 seconds (the longer the better). Reinsert the battery, then press ON button to start it. This is a soft reset, and wipes the temporary memory and empties all remaining power in the circuits. A soft reset does not erase any downloaded apps or user data.
Here is a link to show you how to remove / re-install the battery. (you do not have to remove the SIM card or the SD card)
https://www.youtube.com/watch?v=VFpI1L1e....
If a soft reset doesn't work, you will have to perform a hard reset.
Before you start ensure if you can that the battery in the phone has a reasonable charge.
Do not perform a hard reset with the charger connected to the phone.
Make sure the phone is OFF before you start.
Warning: A hard reset will erase all your downloaded apps and user data. It will restore your phone to factory default condition
Here is a link which shows you what to do. In your case the procedure starts at about 35 seconds into the video clip.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 64
