Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Smartphone lanzado por Sony; también conocido como Sony Xperia Z1 Honami, Sony Xperia Z1 C6902/L39h, Sony Xperia Z1 C6903, Sony Xperia Z1 C6906, Sony Xperia Z1 C6943. Lanzado en septiembre de 2013.
Why is my xperia z1 had a network problem?
Sometimes, network in my device working as usual. And then, it suddenly change it into "Emergency call only". After that, it has a network back. And then, disappear. It repeatedly every second.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario:
Hi,
Try the following.
1. Remove SIM card and reinstall, see how it performs. If still the same,
can you put the SIM card in another phone that is on the same network and see if problem is still there? This will prove whether it is network or phone.
- de
Agregar un comentario
2 Respuestas
The Sony phone will show "Emergency call only" when the signal is bad. May be you are in the bad reception area. If not, check if the SIM has problem or the SIM card reader is loose.
Fue útil esta respuesta?
Puntuación 0
The problem is of SIM Card slot I am also having the same problem.
But don't know how to repair it.
Any ideas?
Puntuación 0
Añadir tu respuesta
Mohammad Shazwan Shaffie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 4,096
