Chromebook not powering on.
My Chromebook is not charging even when I plug it in, how can I charge it and turn it on?
Es esta una buena pregunta?
This will suck. Remove sd card. Power off. Hold volume - and power on. Conferm prompts. You should be in. The suck part is this hard start restors the device to stock. All is lost save what was saved to sd. All ways save every thing to sd card. This is less damaging to you in events as this. I hope this helps.
Fue útil esta respuesta?
If laptop refuses to power on when plugged into power source, your laptop may have a dead battery or the Central Processing Unit may need to be replaced. To address these problems, please refer to our troubleshooting page: Asus Chromebook C300M Troubleshooting.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 3,039
