Saltar al contenido principal
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
Preguntas 222 Ver todo
3G Signal Poor and not Working!
Hello ...
My nexus 5 is driving me crazy.
All of a sudden it stopped getting 3G . It just stayed in 2G (EDGE).
I called the carrier support, they don't know what to do.
This sim works fine in other phones.
Other sims also do not get 3g network on this phone.
I've done a full reset, flashed stock, tried several radios, nothing.
Update (10/23/2015)
If i set it to LTE preferred, WCDMA preferred or LTE/GSM auto (PRL) it finds the network and it connects in 2G EDGE Only
I tested all above and to not work
any help ?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
Have you checked to see what your Preferred Network Type option is set to? Select your preferred network type from options like LTE, 3G, and 2G.
https://support.google.com/nexus/answer/...
If above is not relevant try below.
Have you checked with your network provider that the APN settings (on your Nexus 5, go to Settings > More... > Mobile Networks > Access Point Names> select your provider) are correct for a 3G service?
Check the settings in the phone where your sim works and see if they are the same.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Hi,
Sorry to hear solution didn't help. Here's a link that shows that people worldwide are having the same problem but some have found solutions which worked for them, but did not for others. There are 6 pages to go thru. If you have been here before I apologize.
http://forum.xda-developers.com/google-n...
- de
Thanks , i will cheek it
- de
Añadir tu respuesta
moamendaif estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 5,820
