Kenmore elite washing Machine Code error CL, control locked?
How can I unlocked??
Es esta una buena pregunta?
Mike, this error code most likely indicates that the CONTROL LOCK has been activated. To deactivate the control lock press and hold the drain and spin button for 5 seconds. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min.
Fue útil esta respuesta?
Thanks dude...
For the kenmore elite the Cl error was cleared by the stay fresh button. It also says control lock above it
On some models, the control lock is also the chime button. Press and hold that for 5 seconds, and you're good as new.
On my model, Accela-wash, press and hold the extra rinse button which also has control lock on it
Holding the chime button for 5 seconds worked for me! Thank you! :)
If you look closely under the printed word "Chime" is says in VERY SMALL letters/words "Control Lock" Wheewww - thought I was gonna have to call for expensive service :(
Thanks! Holding the control lock button for 5 seconds helped me! Saved me $80 for a service call!
It worked by holding extra rinse
Thanks Mike holding the chime button for 5 seconds worked!!!!
Worked on my Kenmore Elite!! Just press and Hold the Chime button for 5 seconds.
Y'all another brand of Kenmore it's the Extra Rinse and that is also your Control Lock/ mecv
We have model number 796 and this worked for it. None of the above---unplugging it, holding chime button, etc., worked. Thank you so much!
The same thing for me.. but on my model I pushed the control lock for about 10 seconds and it finally reset.
On my model, pressing the Chime button, which is also Control Lock (CL) worked like a charm,
What if holding the control lock button does not work and unplugging it for a day does not work?
Hi @tdw80715,
What is the model number of the washer?
Acq76909912k-sd-87r 05464 0064
Same thing happening for me Acq76909912k
Ultimas 24 horas: 6
Ultimos 7 días: 34
Ultimos 30 días: 102
Todo El Tiempo: 45,843
5 comentarios
Thanks you. Holding the rinse button worked.
- de Jeannette Trapp
I tried everything Chime button, unplugged and plugged it back but nothing works. What should I do
- de Nafisha Mamdani
Hi @nafishamamdani,
What is the make and model number of the washer?
- de jayeff
I did the same and it didn't worked for me
- de Socorro Ramirez
@socorroramirez
- de jayeff
