Saltar al contenido principal
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
Preguntas 20 Ver todo
My car is running on 3 cylinders.
About 10 months ago the radiator of my car was replaced. The car was overheating periodically. I thought it was the thermostat, but the mechanic did not replace this. The car continued to get hot periodically. I was informed today that the car is running on 3 cylinders. The car is a 2003 with 200k+
Miles. Is it worth it to repair?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Take it to an AutoZone and get a free computer readout so you know what the problem is.
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
First, I would like to know what brought them to that conclusion?
Puntuación 2
2 comentarios:
So many questions could be asked on this situation. Did the mechanic give you any feed back? Is the 4 th cylinder locked up? Have you hooked up a code reader to get the check engine codes? Do you get your fluids replaced regularly? Did you recently have a radiator service?
- de
I concur with the above request for more questions. Can you scan their repair estimate into here? Block out any personal info, of course. One bad cylinder can be many things-- the real question is what is the COST of the repair? That's the REAL determining factor about fixing it or not.
- de
Añadir tu respuesta
Maggie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,706
