water is running back into reservoir
Es esta una buena pregunta?
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
hunter, make sure that your needle valve is not occluded. check on here to make sure that the needle as well as the lines are good.
Rep: 1
My Keurig Elite When you turn on power button it makes a noise but nothing happens(it says Not ready but does not make coffee then cuts oft) does not pump water.
Comentarios:
Remove bottom plate.you will see water pump,sometimes when you hit the pump with a screwdriver handle like a tap it will free the pump
- de Mark B Besho
There are 2 solenoid in the machine,one of them is not operating. Apply 12v to test the solenoid ,replace the one not operating
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 44
Todo El Tiempo: 3,428
what have you checked? What have you tried?
- de oldturkey03
