Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzada en 2011, la Oster Blend-N-Go My Blend es una licuadora de bebidas. Su número de modelo es BLSTPB-XXX-000, donde el "XXX" varía con el color del dispositivo.
Why won't my blender turn on?
My blender is plugged into a power outlet, the arrows on the bottle line up with the arrows on the base, and the blade assembly is fully attached, but it still won't turn on. What should I do?
Es esta una buena pregunta?
Puntuación 6
9 comentarios
Brand new Electrolux eab7300s won't start! We set it up according to the six steps. The lights flash on when we put the blender onto the stand. Any given button we press lights up. But the blender never starts.
Help?
- de
Hi Nuriya OSWALD,
If it is brand new, consult the warranty statement that came with the blender to find out what you have to do to make a claim for a warranty repair or replacement.
- de
where the power
- de
my blender not working
- de
Hello I recently last week bought a Kenwood blender BL440 brand new one
and used it once to make juice but I have tried to use for the second time ,
to my surprise it's not powering on.
What might be the cause?
- de
Mostrar 4 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
This problem can stem from both the blender or even the circuit powering it. First ensure that the outlet you have your blender plugged into is powered and not "tripped". Most kitchens have what are called GFCI outlets that can trip and cut power to appliances. Once you are certain your device is receiving power, remove bottle and blade assembly; then depress the two black micro-switches inside the base of the blender. If your blender still won't turn on then you may have a faulty motor or motor connection.
Also, refer to the My Blend Troubleshooting Page.
Fue útil esta respuesta?
Puntuación 7
8 comentarios:
where the power
- de
Thank you so much FYI. It actually worked on my HAIER Blender which wasn't working for ages, all I did was just depressed the micro switch and it worked.
Thanks again.
- de
Will this work for a blendjet? Because I can't get mine to work, and I've already trouble shot the %#*@ thing.
- de
Still not working I used it 4 times and now it’s not powering on
- de
Do I have to buy another motor
- de
Mostrar 3 comentarios más
Añadir tu respuesta
Walter Hernandez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 71
Todo El Tiempo: 150,834
