Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1526 Ver todo
Touch screen unresponsive when touched but 100% visible
I replaced the screen on my gold 6 plus, I decided to put a black screen on Iit and everything went well until I turned the phone on and the screen was unresponsive to touch. Before complete installation I did test the screen and it worked . The screen has light lines running down the screen please help
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Does the home button work?
- de
I didn't attach the home button backing plate yet because I have a stripped screw and ordered a new plate, but the touch id was still funtioning
- de
Agregar un comentario
4 Respuestas
Solución Elegida
I would take the phone apart again and get it to were it worked before then re assemble slowly and with care checking when possible if it works to know when things go wrong.
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
Sounds like the digitizer flex cable or socket on the board may be damaged. I would inspect those areas under a microscope.
Puntuación 1
2 comentarios:
Could also be a short , did you put all the insulating tape back on?
- de
When I extend the flex cable while it's plugged in the screen becomes clearer, but still lines going through
- de
Your digitizer flex isnt properly plugged in most likely.
Puntuación 0
1 comentario:
- de
Touch input all jacked up after multiple screen replacement attempts
^Try this.
Puntuación 0
Añadir tu respuesta
Josh B estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 340
