Which fuse controls the windows?
2007 Dodge Ram 1500 In the fuse box there is a listing of the fuse sizes and what they go to, but I do not recognize any that go to the windows.
2002-2008 Dodge Ram 1500
Es esta una buena pregunta?
The window control fuse is a
10amp fuse (fuse #25)
Make sure you check your manual for accuracy.
Fue útil esta respuesta?
Thanks for the lead. A good idea, didn't work.
#25 is a 10A fuse shown as the PWR Mirrors, it looked good, but I replaced it with a new fuse--no luck.
I pulled and checked all fuses. Nothing is shown on the inside of the fuse-box cover as anything to do with the windows.
Have same with my 2006. 2500. HELP
04/24/19. Help..._''
Who's has the knowledge, and know how?
Hi Howard. I'm beginning to think there is no fuse for the windows. Nobody can answer the question. Frustrating.
BBRRRRROOOOOOSSSSS / BBBBRRRROOOOSSSSKKKIIIIEEESSSS... this video TOTALLY fixed my truck, can confirm took less than 5 mins:
Thank you Martin!!!!!
I watched the video and it showed me that there was debris in window controlTIPM…
Opened it up, very tight connection- hard to get apart but did it- and there was a little debris on the connector. Cleaned it off, put it all back together… The windows rolled up. Hooray!
Wanted to make clear that my symptoms were that just the windows would not roll up or down… All of the other functions like locks etc. worked fine.so happy!
Thanks Mr.Martin! Just fixed my husband's power window thanks for the video I opened it up just like the video I could see exactly which one was a little darker took my little screwdriver and bent in the metal connector just a little hooked it all back up and it worked!! Less than 5 mins. Thanks Brooke! Women fix things 😆 too !! Ms.Paula murley
Read Marin Rodriguez s answer above it's simple!!
Glad it helped some of y’all! Also girl power!!!
Yea the VERY simple thing to double witness is that the panel does not light up green when the headlights/running lights are in ON position.
Seriously thank you so much Martin this video is a lifesaver. I was about to drive my truck off a cliff. lol
the around 2006-present dodge ram trucks have a TIPM (Total integrated power module). This module has relays built into it that may be malfunctioning. if your wipers, windows, fuel pump, door locks, etc. are not working after replacing the motors and fuses for these it may be your TIPM. its easy to diagnose, simply check with a voltmeter to see if power is going to the motor when you apply the switch for the window, wiper, or whatever. The TIPM is a 1200$ part that is “programmed”or “flashed” to your vehicle. on 2006-2008 models i believe the relay is built into the circuit board without relays and not fixable. on 2011 and later models if you know how to solder you can de-solder the relay from the circuit board and replace with a new relay ~10$ and some time. or you can bypass the TIPM and add in a relay if you know the wiring diagram ~50 dollars and time. On some 2011-on Chrysler/ dodge/jeep vehicles there was a recall which the dealership would add a relay bypass for the fuel pump for you after they realized the relays failing was an issue. this is a good idea fairy by the engineers that does not allow the users of the vehicle to quickly fix their vehicles by just popping a new relay in. i am dealing with this right now and unfortunately my fuel pump is fine and is not getting power due to a failed relay. i hope this helps.
Just had prob. Had to change cigar lighter fuse and it worked
Hi @Howatd Williams,
Don’t know your vehicle but has it got a windows lockout switch on the driver’s door panel?
When this is operated it disables the window controls on the other doors.
Just a thought
Ultimas 24 horas: 5
Ultimos 7 días: 69
Ultimos 30 días: 282
Todo El Tiempo: 75,117
18 comentarios
are your power door locks working
- de Jimfixer
Yes they are working but my right front window don't work I replaced the window motor
- de Martin Gonzales
I have a 2007 Dodge Big Horn . The windows work from the drivers control , but does not work indivualy . I've replaced all the individual switches to no avail . If they work from the drivers control the moters must be good . What would be a quick fix ?
- de Howatd Williams
Can anyone help me out in this here?
I have a 07 Dodge Dakota truck all windows stopped working all at once. I went to the dealership and was told there is a main relay breaker for the windows under the drivers side dashboard. I have yet to locate this alleged breaker to reset it so my windows will work again. It is impossible odds that all 4 window motors quit at the same time. Door locks work great. No windows!
- de emesa1967
Mostrar 13 comentarios más
