Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2193 Ver todo
Replacement Power button not pressing or clicking
Hi all,
My power button stopped clicking in - when you pressed against it the button never moved and didn't click.
I brought a new power button ribbon cable and replaced it.
When I put the button in and hold the bracket against it the button works and clicks, however as soon as I put 1 screw in the bracket the power button stops clicking and goes stiff again.
I have made sure the power button is in correctly, metal bracket down etc.
Ive tried 2 power ribbons now and they all click, just not when the bracket is screwed in.
What gives?
Thanks in advance
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
try backing the screw that holds the bracket out 1/2 turn to a full turn. Sometimes if they get tightened all the way down it will not click
Fue útil esta respuesta?
Puntuación 1
Try taking the back glass off, fold a small piece of paper and put it under the power button for a temporary fix.
Puntuación 0
Añadir tu respuesta
Andrew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 66
