Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
Preguntas 1494 Ver todo
Does iPhone 6+ LCD is replaceable?
Hello everyone.
Just little question, i've seen many peoples talking about changing the LCD of iPhone 6+ will make the home button stop working, and device will not open after for the error.
So, as you can see here, Reemplazo del panel frontal del iPhone 6 Plus
At the step 32, we have to peel the button flex (highlighted in red in the second picture), so does this "button flex" on the LCD are sticked to the LCD or sticked to the metal LCD shield ?
And does we can repair iPhone 6 Plus LCD without changing the original button, and make it work like a new, including touch id function?
Thanks
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
Kits de Reparación de Pantalla LCD de iPhone
La opción de presupuesto, cubierta por nuestra garantía de por vida.
Compra kits
Reduce los costos de reparación, no la calidad.
Compra kits
2 Respuestas
Solución Elegida
If you keep the original home button and put that on your new screen, you will be fine, changing the home button will cause error 53. :-)
Fue útil esta respuesta?
Puntuación 1
Comentarios:
Yes i know for that, like the 5S...
But, i don't really understand what to do at the step 32, "we have to peel the button flex (highlighted in red in the second picture), so does this "button flex" on the LCD are sticked to the LCD or sticked to the metal LCD shield ?"
Thank ?
- Por
in that step, you are releasing the connector from the adhesive that holds it to the screen. Once it is free from the screen, it is still attached to the metal plate, but you just remove the metal plate and flex together, as they come out as one piece (see pic)
Puntuación 1
Comentarios:
Amazing, thank to you!
- Por
Añadir tu respuesta
Phonetech93 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 510
