Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
2.3L 4cil o 3.0L V6, 6ª generación
whered is the idle air control valve located
where is the idle air control valve located
Es esta una buena pregunta?
Puntuación 0
1 comentario
Can tell me where it is located
- de
Agregar un comentario
3 Respuestas
Solución Elegida
deborahfoley70, you did not tell us what engine your Honda has. The Idle Air Control (IAC) is marked on the images posted.
Location on the 4cylinder engine is center rear
Location on the 6cylinder engine is left side of the engine
Fue útil esta respuesta?
Puntuación 6
1 comentario:
Thank you so much! Oldturkey03 !!!!! I have a 4 cylinder V- TEC. Man every other site I reviewed showed 6 cylinder V-Tec's. IAC valves - now I gotta figure out how to remove it. I'll get r done.
: - ) Mississippi Richard
- de
This is always located just aft of the throttle body intake. It will usually have a 2 wire cable going to it. This valve keeps the engine from stalling when the main throttle butterfly is closed.
Puntuación 2
Mounted underneath throttlebody with 2 Phillips head screws that be difficult to remove on high mileage vehicles
Puntuación 0
Añadir tu respuesta
deborahfoley70 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 42
Ultimos 30 días: 155
Todo El Tiempo: 39,659
