My iPhone is broken with color on it
what would i do here is the battery problem?
Es esta una buena pregunta?
That will probably be the lcd that's damaged. When you buy a replacement screen you will have to buy the glass and screen together as an assembly, so you will fix this problem with a new screen.
Fue útil esta respuesta?
so i just need to buy LCD replacement.
You will have the buy an assembly like this one:
http://www.ebay.com/itm/New-Replacement-...
This is the lcd and touch glass together. You can not buy an lcd and touch glass apart because they are attached with a special kind of glue.
It is always handy if the speaker mesh is included, this is the metal thing that covers your ear speaker so no dust can get in the phone. If you have to transfer this you could be annoyed because the adhesive might have come of and is annoying to keep in place.
Here is a tutorial on how to replace the screen on a 4s
Step 40 is very important. If the cable is bend between the frame it will brake your display! Be very careful at that part.
Goodluck with the replacement.
you really good,
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 80
