Saltar al contenido principal
Modelo A1181: procesador Core 2 Duo de 1.83, 2, 2.1, 2.13, 2.16, 2.2 o 2.4 GHz
Preguntas 1203 Ver todo
Telling if my computer is of the Santa Rosa chipset?
The MacBook Core 2 Duo (Model A1181) w/2.4Ghz processor can accomodate up to 3 GB of ram normally. Computers with the 'Santa Rosa chipset' can accomodate 4 GB. How do I tell if I have a computer with the Santa Rosa chipset.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
the 13" Macbook Core 2 Duo was updated to the Santa Rosa chipset in Nov 2007. this model is aka MacBook 13-inch Late 2007.
According to Mactracker, the machine ID for this model is: "MacBook3,1"
this machine ID is unique to the particular version of a model, unlike the generic model number A1181 which spans several generations of this machine
you can find the machine ID for your MacBook by going under the Apple menu and select "About this Mac..." then click on "More info..." - this will launch System Profiler. your machine ID is listed.
if your Machine ID is "MacBook2,1" then you don't have the Santa Rosa chipset and you can only use up to 3GB RAM. if your Machine ID is "MacBook3,1" or higher you have a Santa Rosa machine and can use 4.0GB RAM as specified by Apple (actually, 6.0GB will work)
edit: you mentioned your machine is 2.4GHz - then it looks like your machine ID should be: "MacBook4,1" - this would be a "MacBook 13-inch Early 2008" version
Fue útil esta respuesta?
Puntuación 1
Great! Thanks a lot. You were correct in assuming that my machine id is 'MacBook4, 1'. You said 6 GB will work. Does that mean that if I put two 3 GB chips in then it will use all 6 GB or will it only use 4 GB? I remember seeing something about some of the computers only being able to utilize 3GB even though you might have put in 2 2GB chips into the computer.
Update: If found the answer at this link...thanks for all the help!
http://forums.macrumors.com/showthread.p...
Puntuación 0
Añadir tu respuesta
Jared estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,385
