Saltar al contenido principal
Guías de reparación, desmontaje y soporte para lavavajillas.
Preguntas 705 Ver todo
dishwasher motor connection 110v
hi. all...
i have a dishwasher motor and i want to use it to make a cheese grinder, so my question is how to connect with 110v direct to work... the other piece with the white plastic i don't need.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
7 comentarios
it come out of G&E DISHWASHER..CAN I REMOVE THE SOLENOID OR NOT..
- de
Give us more info on the motor itself. Yes you should remove the solenoid etc. Since it appears to be a pump there should also be an impeller at the end of the shaft etc. Post more images of your pump. right now it looks like the motor connects to the pump housing via the screws on the top corners. So, the solenoid and the motor are connected to the pump housing. You may have to remove it, but it will depend on the design of your cheese grinder.
- de
I going to remove the solenoid and the white plastic and the side pice, so if I connect the power on the top connecter you think it should work,
- de
That is the way I would proceed.
- de
OK, i try tomorrow to connect the power??
- de
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Respuesta Más Útil
vitodeluca, it might help a bit more if you tell us what model motor this is and/or what dishwasher it comes out of. Right now it looks like the Recirculation Pump motor. The part on the left looks like the solenoid to shut the flow of. The AC (power)connections are the once above the thumb in the picture.
update
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
vitodeluca estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 263
