Saltar al contenido principal
Harley-Davidson Sportster Motorcycles from 1986 to Present.
How do I change my starter?
how can i change my starter for a 07' sportster
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
How to change a starter on a 1999 sportster
- de
Agregar un comentario
2 Respuestas
It won't be fun.
1. remove battery
2. remove primary cover (leftfoot peg probably needs to come off to do this)
3. remove rear exhaust pipe
4. remove (you might get away with just loosening this) the drivebelt front sprocket cover (right footpeg and front muffler might interfere)
5. remove starter wiring
6. remove starter bolts
7. remove starter
reverse procedure to install
In addition to the starter itself, you'll want to have gaskets for the following:
- rear exhaust port
- exhaust crossover tube
- primary cover set
and oil to refill the primary chain case
Fue útil esta respuesta?
Puntuación 0
How do you change starter in 86 harley sportster 883
Puntuación 0
2 comentarios:
I think that is first year evo, so it should be similar to above.
- de
Ok thanks it's alot of work to remove the starter
- de
Añadir tu respuesta
Israel Sandoval estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 7,844
