Saltar al contenido principal
Repair and support information for the Asus ZenFone 6. It utilizes an Intel Atom 2580 processor. Was released 2014.
Preguntas 40 Ver todo
How to replace the lcd and screen of a zenphone 6?
My 2nd phone, which is the zenphone 6, fell down on the street, and now the glass is broken and the LCD is too. How can I replace those? I am asking here, because I haven't found a guide anywhere.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 10
Agregar un comentario
6 Respuestas
Respuesta Más Útil
You must buy a digitizer and LCD screen assembly. You cannot remove the digitizer separately so you must buy the whole assembly even if the LCD screen it self isn't broken. The cost around $60. Once you have the replacement, TURN THE PHONE OFF. remove the backing that just snaps on/off (in my case the snap backing was red). Then with a small screw driver carefully remove the screws holding on the black plastic backing underneath the red snap backing. Once the screws are removed and put where they will not get lost, take the black backing off ( once the screws are removed it will snap on/off). CAREFULLY REMOVE ALL CIRCUITRY. Try not to directly touch the circuits as static electricity could short them. the next part is alittle messy and grizzly. They mount the screen/digitizer with very sticky adhesive and the only way I could get the old assembly off was by chipping some of the glass on the corner and prying a screw driver underneath until the digitizer and LCD came off. BE VERY CAREFUL. route the ribbon cables through the slots. Glue the digitizer to the phone( don't use super glue) if it is hooked up correctly and nothing is broken it will be good as new
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Hello, what type of glue we can use? is it LOCA Adhesive?
Thanks :D
- de
I havê this problem too. $130 to fix it in Brazil :'(
Puntuación 1
Hi,my Zenphone 6 is giving me problems.Firstly the apps start to hang and some of my apps can't open especially Facebook.Then I need to off it and on it again but the problem is still there.What am I suppose to do?
Puntuación 1
The process is explained above
Puntuación 0
hello am have zenfone 6 end bye one screan with frame model 13AT end ma phone don't work becose is 13AZ namber. Is this problem becose is deferent namber or model. Pleas help me. Ma mail is trollojoo@gmail.com
Puntuación 0
yes my dispalay and screen broken
Puntuación 0
1 comentario:
i want to price of display asus 6
- de
Añadir tu respuesta
John estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 11,690
