Saltar al contenido principal
Información sobre reparación de herramientas utilizadas para una tarea específica como arreglar, construir o cortar. Aprende a usar las herramientas que funcionan para arreglar las que no funcionan.
Pregunta Cerrada
Some one using TI EV2300 to program/hack a Battery back
TI EV2300 is a tool to program BQ series battery gauge.
I'm considering to get my A1185 out of "Permanent Failure" using EV2300.
Some one ever tried that or have some info/suggestion?
Thanks!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
did you check the lipo cells first? are the fuses ok? - if a battery fails - it's most likely the problem of the cells and not the pcb inside the battery
so checking the voltage of every single cell and their fuses would be my first step - but that involves disassembling the battery (be careful and don't bent the cells)
Fue útil esta respuesta?
Puntuación 0
1 comentario:
'cause i'll replace the cells and the g**d*** "self destructive" fuse. and i know what i'm doing.
just need some tool to reset BQ20Z80 status.
i don't know if this can be done by just programming SMBus...
- de
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,794
