Missing what I think is a Resistor but not sure exactly.
Ok so I have a water damaged IPhone 5c . I disassembled and cleaned with 99% alcohol but still nothing so i proceeded to remove the Metal shields where i found more corrosion which i cleaned with a brush and alcohol .
After cleaning i reassembled with a new battery . The phone shows no signs of life other than the board gets hot enough to burn in this area SHOWN IN BLACK .
Now i noticed that what looks like a resistor but is probably not was covered in corrosion and looked damaged and seemed to be the source of the heat. would burn finger when touched. So i successfully desoldered it and no more heat but still no life in the phone. I'm looking to find out what this part is called so i can get a replacement to see if it solves the issue.
Part shown in black
These images were taken from ifixit i just highlighted the part i am referring to.
Thank you in advanced.
Es esta una buena pregunta?
