Frost buildup on freezer back wall in GE Fridge
Hello -- I have frost build up in the back freezer wall of a GE fridge (model; GSH25JSXL SS). As a result, it is preventing any ice cubes to be formed and is causing the refrigerator to be less cold than usual.
I called a local repair shop on the phone and they want to replace the defrost heater, but I'm not sure.
What's the problem cause and suggestions to fix it? Thanks in advance!
Es esta una buena pregunta?
15 comentarios
ABCellars answer sounds good but in the search for anytime similar for my GE side-by-side refrigerator #GSS25XSPABS in the freezer parts section I can only find a Refrigerator Temp Sensor and Defrost Thermostat. Would either of these be another name for a defrost heater, limit switch or timer?
- de CK
Solution. Store your food in a good quality esky that will keep it cool or switch to non perishable food for a day or two-Turn the fridge off and make sure everything is out of the fridge and freezer including ice build up. If possible leave both doors open -take care if you have small children make sure they can't get into the fridge freezer spaces and close the doors-jam something in the space. Check the back to see if there is any dust on anything - vaccum this up-carefully not to break anything. Once the fridge has been off for awhile feel the outside fridge/ freezer walls to see if there are any cold spots-this is ice build up in the walls. Leave fridge defrost until this area becomes neutral-don't be impatient-this will take a day or two. Voila fridge is fixed. Get a fridge thermometer to check your settings when you switch it back on. Humidity is a bugger.
- de canlen
How can the problem be fixed by just letting the refrigerator defrost on its owm for a day or two ???
- de Bo Gregory
I agree, Bo. I am now completely defrosting my GE every two weeks. All moisture out, completely dry, two days. Fire it up, and it frosts up in 10 days. Completely blown off compressor, coils, etc in back. A clue might be there is no drainage coming out to the evap pan, so I am suspecting the "defroster heater". The water in the door has never worked because the line freezes up immediately! This was an expensive frig and is only about 6 years old.
- de Jim Penson
Same problem--mine is an HSM25GFTSA, and I started having to defrost it manually about three years after I bought it. I've replaced the defrost heater several times, along with the defrost thermostat and thermisters. No more GEs for me.
- de Buffy Finestone
Mostrar 10 comentarios más
