How can I make my mac faster?
My mac sometimes is slow but sometimes it takes to long to respond. but i want to make it fast like when i bougth it.
Es esta una buena pregunta?
I would run a utility like Snow Leopard Cache Cleaner and delete all temp files and clear all caches. I have that machine as well and I found that a RAM upgrade made a nice difference (4GB). You can always get a faster HDD as well. another suggestion is that you defrag your drive and optimize your files. If your drive is close to full capacity, I would do a clean up of all large and unused files and give the drive room for swap files.
I also recommend using Monolingual, a nifty little software that removes all unnecessary languages from the OS and applications. It even gets rid of universal binaries, which can speed up the opening of Apps.
Another suggestion is to upgrade to SnowLeopard if you dont already have it, back up all your data and do a clean install of the software.
Fue útil esta respuesta?
All good suggestions. + Ralph
I've heard this about the cache a lot and had some luck, but it seems to me like the whole point of the cache is to make things run faster. Why does this work?
Honestly Sterling, I couldn't give you a clear answer on that. I would definitely agree with you in the part about the caches making things faster, but I can also imagine that these caches can also become congested with temporary files, thus causing a slow down. Maybe? I dunno, but I have had some luck and improvements with clearing out caches every once in a while.
Lets use Safari for an example, if it saves lets say a file for every site you visit in one month. Unless you visit the same sites all the time, some of these files are stored in the cache but aren't being used, therefore they're just taking up space in the cache. It's a shot in the dark, I dont have the technical know-how to really give you a concrete answer.
My Dad bought me a MacBook for college that was really expensive so I am hesitating to buy a new one because mine got pretty slow. Eventually I found a site ( http://www.detoxmymac.org ) and its working perfectly again!
The more cache files the APP or OS have to search, the slower the app becomes as it has to wait for the search to finish. By cleaning out old outdated cache files, the search time is much shorter. So many websites today are constantly changing their pages making caching almost pointless over a long term (say a week or more). That's why keeping the caches cleaned out will net a speed increase. A once a week routine should keep everything sparkling fast.
I am in the same boat as you. I just upgraded my late 2008 MacBook with a new SSD, a 750 GB 7200 RPM HD in place of the optical drive, and 8 GB of RAM. Previously I had a measly 4 GB of RAM and a slow 5400 RPM 250 GB HD. Things should be screaming now!
Hey, u still got that sooped up mac? Is it running well? I'm thinking about putting HD in place of optical drive.
If your Mac hard drive has too many fragmented files then it may slow down your Mac. Defragmentation is the process which helps to keep all scattered files together in hard drive and increase your Mac performance. I would like to suggest all Mac users to use Stellar Drive Defrag tool to defrag Mac disk.
You can minimize memory usage in the following five areas.
1. Clean up your desktop. A clean and tidy desktop not only allows you to look good and relax but also reduces memory usage.
2. Although extensions in web browsers can very helpful for us to use. But sometimes there are some extensions that you won't use for a long time. Why not consider deleting some unnecessary browser extensions at this time? Removing some unused browser extensions can also reduce the use of memory.
3. Delete junk files. When your Mac has been used for a long time, you should find that your Mac has a lot of files that you haven't used for a long time, especially if the large files are especially memory-intensive. There are also old iOS and iTunes backups, cache files and browser caches, duplicate photos and files, and software that hasn't been used for a long time. These are also very memory intensive. To remove these junk files, I suggest you use some Mac cleaning tools. For example, iMyMac's Mac Cleaner.
4. Do not open too many windows at once.
5. Restart the Finder tool. Finding large files with the Finder can take up a lot of memory.
Reducing memory usage is a necessary condition to keep your Mac running smoothly. So keep your Mac computer healthy and remember to clean it up often.
Remove un-useful files and folders and create a huge space in your macOS memory. You can try advanced uninstall manager to delete any data on mac.
Hi, get the Drive Genius 3 disk and defrag your hard drive. after a long period of constant usage your hard drive will need to be defrag, just like the PC, you must do maintenance work on your machine.If you have maxed-out your memory then you should be fine, just concentrate on doing the defrag of the hard drive.
You can make your Mac faster. You can go through below link. With the passage of time Mac gets slow because of system junks, caches, language files, unwanted applications, duplicate files.
I have the same problem...just asking how much does the language files take up? :)
Upgrade your ram and use clean my mac app to remove all junks and caches. After that use onyx app for check S.M.A.R.T status check and repair. You have to do this process for weekly once. Your mac will be s,art and healthy,..
There are various techniques which helps you to speed up Mac. One of them is defragmentation, which helps to keep scattered data in organise form in Mac memory.
Read here:- http://www.websigmas.com/web-tech/how-to...
You should remove all unwanted data from your Mac as soon as possible. You can use OnyX cleanup tool to sped up your Mac.
Defrag your mac filesystem? From what I understand is, we don't need to defrag a UNIX FS. they use sequential writing & not like windows or WAFL. Does defrag really improve the performance, is there a way to measure it?
Thanks
G
Optimize you mac by deleting unwanted file, cache & junk files. These files take so much spaces and also slow down your device speed and performance. So time time you can delete these unused files. Also you can use third party software like disk clean pro.
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 28,491
