Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
La actualización de abril de 2014 del MacBook Air de 13" de Apple presenta procesadores i5 e i7 de doble núcleo actualizados, además de un rendimiento ligeramente mayor de la batería.
Preguntas 246 Ver todo
Backlight Non-Functioning after Water Spill
I'm trying to fix a MacBook Air 6,2 (13", Early 2014). The previous owner spilled water on it, but immediately took it to a repair shop, where it was disassembled and dried. As a result, the laptop doesn't appear to have any corrosion, and everything works but the backlight. The LCD functions, so I can use the laptop as normal if I use a flashlight or headlamp to shine light on the screen.
I've done a bit of research, and it seems like this is pretty common after a water spill and happens because of a blown fuse which can be replaced (LED display and backlight not working).
I have access to an electrical engineering lab (and EE friends), so I have all the tools I need to test and repair the MacBook.
Can someone tell me which componenets I need to test with a multimeter in order to diagnose which one is the problem? Here are some pictures of the logic board:
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
1 Respuesta
Highly likely the backlight driver IC has fried and will need replacing.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Jimmy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 189
