Saltar al contenido principal
Procesador Intel de doble núcleo a 1,7 GHz (Turbo Boost de hasta 2,6 GHz) con 3 MB de caché L3 compartida
LED display and backlight not working
After falling a glass of water, I cleaned the entire motherboard with isopropyl alcohol and everything works fine except the backlight and the LED screen, ie pictures but you can see this as having no brightness. Know if there is a fuse you can check.
You can see on the picture that if you approach a light you can see the contents of the screen.
Can anyone give me some help?
I can check the fuse as I have a multimeter, on the mosfet I have no idea how to check.
If you can tell me exactly which elements and how you can prove greatly appreciate it.
Thank you very much!
Update
The Serial Number is XXXXXXXXDRV6.
The image of back of the logic board reverse.
Es esta una buena pregunta?
Puntuación 2
1 comentario
what are the last three digits of your computers serial number? that will help us to properly identify your computer
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Arturo, yes there is a fuse. It is reference designator F9700 and is a 3AMP 32V in a 467package. You will need a multimeter or ohm meter to check it for continuity. Also check the accompanying Mosfet. Any logic board repair will require special tools and great skills. If you can post an image of your logic board with your question, we can point out the parts to check. Hope this helps, good luck.
Update
F9700 is the fuse and Q9706 the power Mosfet FDC638APZ, Q9707 is a SSM6N15FEAPE
You need to check the voltage on the contacts. this is not easy and if your probes touch other contacts, you will cause further damage. You should get 12.4 Volts on those
further update
Here is the location of the LP8550 LED driver
Fue útil esta respuesta?
Puntuación 6
7 comentarios:
Ready the image :)
- de
Apparently the fuse is fine (I get continuity), how could check the mosfet?
Thanks
- de
Bad news.... :(
The fuse and the mosfet are OK (apparently), I check with the huntron tools and the mosfet FDC638APZ is fine but no power.
Could you tell me how this is powered mosfet to try check where the power failure??
In the scheme two resistance and two mosfets appear, but I can not find them.
The serial number finish in RV6
Thanks!
- de
double check your serial number. RV6 does not give me any return. Despite the schematic, I only show one of the mosfet on the logic board. I updated the original image with the location.
- de
Arturo, since you seem to have access to some great tolls, have you checked the LED driver LP8550 yet? It is on the underside of your board.
- de
Mostrar 2 comentarios más
Hello,
I'm having similar problem, i'm getting 7.2V at the fuse, but based on the schematic, i should be getting about 12v. Is this correct? I'm also getting about 3v at the backlight enable. Would you have any suggestions as to what might be pulling my voltage down and also what is delivering the 12v power? Thanks.
Puntuación 0
i'm having the same problem. fuse has continuity and puts about 8volt. Would this typically be a driver problem or is it the mosfet?
Puntuación 0
did it started working i am also having the similar problem the backlight and led is very dim ..everything is been running fine ..i haven taken a service technician she said the motherboard may have been damaged ....is it true it related to the motherboard problems
Puntuación 0
Añadir tu respuesta
Arturo Blanco estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 28
Todo El Tiempo: 8,569
