I know this thread is over a year old, but I actually got the same notebook from a friend and I'm reusing it as as NAS, and I was facing the same problem.
My first attempt was unplugging ac, battery, and bios battery (at least 24h) but it didn't resolve anything.
Then I discovered why: UEFI and FastBoot are enabled, so your keyboard-interactions won't work @ startup. So what is starting up? The Windows BootManager. Then I tried following: When you insert a windows installation media (DVD/USB) it WILL start this one up.
When you get so far, try a FirmwareRepair (not necessarily) because /at least for me/ after inserting the Installation Media (!mportant that it is from Windows) I could enter the BIOS again, then changing from UEFI to Legacy/FastBoot-Disabled
Hope this helps anyone who's facing the same problem
cheers!
10 comentarios
my hard disk crashed on my acer aspire v5, i want to replace the hard drive. pls how can i go to into the bious to boot from CD ROM or USB ? pls kindly help me.
- de Mike
hi.i have same problem.i used bootable usb with some file transfear bootable program.do not waiting to program fully load,i remove the usb stick,then i can get to the bios.changed boot priorities,but it wont save no f10 no save and exit.then i just changed from uefi to legacy,so now i can install windows,but only from dvd and i still cant go to bios setup without that bootable program.anyway there i can change just from uefi to legacy...so installed w8 and just using till next "operating system not found"
it is motherboard problem i think.
- de Saulius Kriksciunas
Hi . everion.
i have the solution.
firds : you need format the new hard disk in other computer with os wondows 10 or 8.1.
second: disarm the acer Aspire v5 and remplace the hardisk .
it´s all...
- de Crisoforo
I hаd a ѕіmіlаr іѕѕuе, соuldn’t gеt tо BIOS menu оn mу Acer Aspire.
Fіnаllу I mаnаgеd tо rеѕоlvе thе рrоblеm
Follow thіѕ guіdе hеrе: http://bit.ly/AcerBios
Hоре thіѕ hеlрѕ
- de Wendy
Check here how to enter Bios on Acer laptop:-
https://www.howali.com/2017/07/hp-acer-d...
- de tony
Mostrar 5 comentarios más
