Saltar al contenido principal
2.3L 4cil o 3.0L V6, 6ª generación
Preguntas 426 Ver todo
Where is the computer to the transmission located?
The car runs fine but after a while of driving it goes from high gear to low and I can stop and put it in park and cut it off and back on and it will change fine for a little while. I had this similar problem in my 1992 and all I had to do was replace the transmission computer and now it works perfectly so I was thinking this one may have the same problem.
Es esta una buena pregunta?
Puntuación 4
6 comentarios
What model and what year?
- de
1999 Honda Accord.
- de
Well I took it out and the part has SRS on it instead of PCM is that still the right part?
- de
Absolutely NOT correct. The SRS unit controls the air bag system and ONLY the airbag system.
- de
Where is the pcm computer
- de
Mostrar 1 comentario más
Agregar un comentario
1 Respuesta
Solución Elegida
Lamica Stone, the electronic control system consists of the Powertrain Control Module (PCM), sensors, and six solenoid valves. Shifting and lock-up are electronically controlled for comfortable driving under all conditions. The PCM is located below the dashboard, under the front lower panel behind the center console.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Also pulling the fuse, resets the computer as I understand it. But as you described.... I wound up redoing the Tranny. PCM is easy to get to and remove. However, KNOW!!! they are keyed to the ignition! Can't put a new one in unless Honda hooks the new one up to a computer and downloads your configuration into it. You'll be DEAD. $100 is the charge. VIN will reference the correct part number. But it is on the side as well (even better) There's a couple of excellent cross reference sites. I may even have a PCM
- de
Añadir tu respuesta
Lamica Stone estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 47
Todo El Tiempo: 30,843
