Saltar al contenido principal
Versión CDMA del iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben reemplazarse como una unidad. Compatibilidad de 16 o 32 GB / Modelo A1349 / CDMA.
Preguntas 295 Ver todo
4.8mm Standoff Not working
So i am trying to put my iphone 4 back together, but when i try to screw the screw that holds in the grounding clip on the wifi antenna, it will not go in. Can i buy another standoff somewhere for cheap? Preferably on ebay. I have seen some screw sets but I dont know if the standoff is the 3.6 or 4.8mm. Its a iPhone 4 Verizon.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hi
The stand off is 4.8mm. http://www.ebay.com/itm/NEW-iPhone-4-4G-...
The screw will be in that kit, you cant buy the screw by itself.
I have done countless iPhone 4 and 4s screen replacements the wifi will still work with out the ground clip (but its not recommended to not have one) Do not use the phone for a long period of time without the ground clip. I would try to get that screw asap so you don't do damage to the wifi connector.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Vlad Nikolayev estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 217
