Saltar al contenido principal
Released in 2008, part of the Air Warrior line of Buzz Bee foam dart guns. Features include a large ammo capacity and an automatic firing mode. Repair in most cases is easy, requiring only simple tools.
Preguntas 4 Ver todo
How do I stop darts from getting stuck and jamming the gun?
I've noticed that when I fire and use my dart gun for extended periods of time darts have a tendency to get stuck near the tip of the gun rather than firing out normally. Is this due to a defect in how the gun was built or some other issue?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario
I have a Nerf Ultra Speed and for some reason the bullets are not coming out of the mag and making it jamming and shooting slowly, why is that?
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
If your darts get stuck, it might be your gun or the darts themselves. Sometimes after being fired many times and successfully hitting many targets, the darts will get bent or weakened, this will jam the gun and they might get stuck. Check out the Troubleshooting Page for more help!
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
It is actually due to not pulling the trigger hard enough. When you pull the trigger it pushes the bullet into the powered barrel so if you half pulpit it gets jammed between the ammo clip and the barrel!
- de
You might have to use a special thingamajig. Moira is right.
The darts might be chewed up or damaged from another gun.
- de
I think that anonymous is wrong because that if you only pull the trigger hard, it only shoots. It has nothing to do with gun jams. Check the bullets and the gun, Garmsen.
Puntuación 1
if you see a very small button on the side of your nerf gun, press it and $!^& the gun and it should unstuck
Puntuación 1
my nerf gun was stuck bc it is a xshot zuru gun with balls and then i tryed what soyboy told us and it works thx soyboy
Puntuación 0
1 comentario:
my gun did the same thing
- de
Añadir tu respuesta
Reed Garmsen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 22
Ultimos 30 días: 113
Todo El Tiempo: 14,195
