Saltar al contenido principal
The Fosera Scandle 200 is a solar powered device that can be used as a lantern and/or a charging station for electronic devices.
Preguntas 2 Ver todo
Why is my device not holding a charge?
I've had my device for a while now. Lately, it only works when plugged in.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
If your device is not holding a charge after a full charging cycle then your battery has likely reached the end of its lifespan. Rechargeable Lithium-ion batteries have a limit for the number of charging cycles they can go through, and as this limit is approached the battery will exhibit much a much lower capacity.
See heading "My device only works when the solar panel is attached" in the troubleshooting page at:
Fosera Scandle 200 Troubleshooting
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Vincent C estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 249
